louisianboy
I own both a Trooper and a Montero, I really like them both, they are both great overland vehicles and are very reliable. My Trooper has 360,000 miles and is now in need of an overhaul, I have taken it to some unbelievable places and I have a great deal of confidence in it, I have worn it out. The Montero on the other hand was my girlfriends car, it is also worn out with 270,000 miles, but I did not spend the hours doing that, it too is a great off-road vehicle. To compare the two: If you are looking to spend money and and get the vehicle the way you want it specifically for overland, I would start with the Trooper. If back seat space is important I would also go with the Trooper. The Montero has a nicer ride and in general is more comfortable, if you are looking for a every day driver that you can use for overland excursions I think I would lean towards the Montero. Overall I like the Montero and I will usually take it but the worse the terrain the more I start leaning towards the Trooper.
Of course this is in addition to the many points that have already been made here the Montero's lockers and it will take bigger tires without lifts, the Trooper's greater ground clearance and longer travel front and rear and etc.
