Slickrock Road and Owens Valley, CA June 2012
tizzdizz
Geologist
We recently did a 4-day trip to eastern California from the Bay Area and had a fantastic time. We came back with lots of stories and pictures along with a few dents and dings (ok more than a few in some cases). We did nearly 1000 miles in 3 and a half days, and it was just what I needed in a get-away road trip.
I've never done a trip report, so bear with me, but I plan to write up each day with pictures and videos. Note, the videos do have adult language. The videos have been started and a couple are already uploaded, so I'll post those in with each days' story and photos.
Here's the original trip thread:
http://www.expeditionportal.com/for...to-Mono-Lake-and-Slickrock-Road-June-28-July1
And our itinerary:
Thursday June 28:
After work, leave San Jose for Utica Reservoir near Bear Valley off Hwy 4. Find a campsite for the night, then:
Friday June 29:
Run Slickrock Road trail from south to north (backwards) via Spicer Meadow road, and out near Alpine Lake. After completing the trail, we will continue NE on HWY 4 to HWY 395, then South to Rock Creek Lake, which is near Bishop. We can set up camp at any of the campgrounds by Rock Creek, so that we are set for the next two nights. (Instead we split up and some stayed in a hotel in Bridgeport, while others made camp in the dark at Lundy Lake).
Saturday June 30:
Run Sand Canyon Road trail which connects to Wheeler Ridge. This will be an all-day outing, but our campground will be close by (Rock Creek). The views from Wheeler Ridge are supposed to be pretty nice, so I'm especially looking forward to this one.
Sunday July 1:
Pack up, then run Long Valley Caldera trail for approx half day before heading home. (This didn't end up happening. Instead we had to track down a tow dolly... Stay tuned for that story...)
tizzdizz
Geologist
Day 1: Utica reservoir
Day 1: Utica Reservoir
We met with the San Jose crew and hit the road at 3:30 pm.
Untitled by tizzdizz, on Flickr
The crew:
Brad and I in my '03 Grand Cherokee
Ian and John in Ian's '98 Grand Cherokee
Chris, Katie and Geanmarco in his jku rubicon
Whitney in his '72 Wagoneer
Carlos (cap510 on here) and his family in his '94 Montero
Whitney had started with a bone stock rig three weeks ago and just finished a spring-over axle lift, new 33x10.50s and just last night at 10pm finished swapping his motor and started it up. The first real drive with the new motor was this morning. At first, it performed perfectly, apart from the occasional gas sloshing out of the filler neck.
Ian had recently swapped axles (High-pinion Dana 30 front, Ford 8.8 rear), installed gears and lockers, long arm suspension lift, along with numerous unforseen cooling system issues. He ran hot climbing hwy 4 but otherwise did well. He also just fixed his Ac last night. How often do you finish your last-minute repairs and preparations early enough to add a luxury like AC into the mix?
The only recent work on mine was some new sway bar endlink bolts, hose clamps for the vacuum hoses, new steering stabilizer and oil change, along with transmission fluid and coolant flushes. I also wired an aux input into the stock stereo.
Carlos had a number of last minute fixes and tweaks as well. He brought his son, daughter and cousin and miraculously found us at our campsite around 11 pm.
Getting to the Utica Reservoir campsite via Spicer Meadow Road was a breeze except for the last 300 yards, which were separated from us by a water crossing. One of the guys had stayed at the site before and crossed with no problems, but this time around the water was pretty deep.
The first 3 rigs made it across fine. I had water up to my hood but kept my speed and wake and had no issues. Definitely the deepest water crossing I'd done, and I was probably pushing my luck as my air intake is lower than the height the water came up. Gianmarcos Rubicon had some water come in the doors but nothing too bad.
Poor Whitney made it almost all the way across when his mechanical fan bent from hitting the water and cut up his radiator. He limped out and I towed him the last few hundred feet to our campsite. The plan was to run to the nearest town (Arnold) in the morning and find any radiator that would work. We had barely even left the pavement and we were already having issues. Oh well, nothing some alcohol and a bunch of engineers can't fix, right?
So, we setup camp, had some delicious salmon and brie. Ian broke out his guitar and I got out my djembe. Oh, and we may have had a few drinks to kick off the trip.
Here's the video for Day 1
tizzdizz
Geologist
Day 2: Slickrock Road
What a heck of a day. It started early with most of us waking up before 7 and Ian and Whitney starting the radiator hunt at 6:45. While we cooked and ate bacon and muffins, they drove down the mountain searching and wound up going all the way down to a radiator shop in Sonora. They just so happened to have the exact fit replacement part, only in aluminum! Not only a direct bolt-in but a nice upgrade over stock. They bolted the new radiator in along with a spare electric fan Ian just so happened to have with him. We packed up, ate an early lunch and hit the trail.
Since we were running the trail backwards (south to north), we hit the Staircase right away, and all navigated down it fine. It's one of the toughest if not the toughest obstacle on the trail, but it's easier going down than climbing up. The 3 boulders across the trail at the bottom were difficult to navigate around, but we made it eventually. (I may or may not have gained ground clearance by caving in my rocker panel even more than it already was).
We drove through several rock gardens, then came to Slick Rock. In the direction we were going, it was a steep climb uphill on a pretty slick rock (hence the name) that tops off with an off-camber left turn that will slide you right into a VW-sized boulder if you're not careful.
Whitney's Wagoneer started having some fuel delivery issues (possibly fuel pump, possibly elevation/carburetor) which kept his jeep from running for long. He made it up the first 1/2, but then the engine died out, Ian towed him up the rest of slickrock, which proved to be quite a challenge once he got to the turn at the top.
The jeep still wouldn't run, so he got towed up to the next obstacle. At that point, his passenger front tire got stuck in front of a big boulder which we couldn't tow him around. After an hour and a half, he got a nice strong tug, against the boulder, which wound up pushing that wheel backwards and snapping the back end of the leaf spring. After some inspecting and thinking, we finally put a strap around the blocking boulder and dragged it a few feet out of the way. Ian proceeded to tow Whitney's Wagonner through the rest of the trail, over every obstacle, without power steering or brakes.
By the time we reached Lake Alpine at the end of the trail, Things were not looking good for the poor Waggy. Upon closer inspection, the damage from towing had shattered the transmission bellhousing and snapped the transmission mount. Both front shock mounts were ripped out, and the driveshaft was the only thing keeping the transmission in the jeep.
Whitney decided to get a campsite for his jeep while we continued on for the next 2 days, and we would deal with it on Sunday.
Check out the videos below:
LR Max
Local Oaf
Your trip report is lacking one thing....MOAR!!!!
Great trip. Love the Waggie. Nice to see someone else on the trail with old iron. But I will admit, those newer vehicles make it look too easy!
tizzdizz
Geologist
OK, day 3 was a big day. Half of us had camped in Lundy Canyon for the night, and half were in a hotel in Bridgeport. We all inadvertently split up on our way to meet at the trail head. Brad and I got some breakfasty snacks in Lee Vining (sadly no ice cream, as Mono Cone was not open yet). Ian had to run to the nearest parts/hardware store in Mammoth to fabricate an air dam, as he was having cooling issues due to airflow with his radiator. :Mechanic: We all ended up finding eachother at the Sand Canyon Trailhead later that morning, and we hit the dirt! :truck:
One thing I love about the Mono area is all the volcanics. The volcanic features are still young and the area is still active, with at least a dozen eruptions within the last 1000 years. Here you can see a (somewhat grainy) southward view of the Mono-Inyo Craters, south of Mono Lake. They get younger/newer to the north, and the youngest ones are actually in the lake. You could make a big trip of just looking at the volcanic features of the area without ever doing any real 4x4 trails. I also highly recommend spending some time at the Visitor's Center in Lee Vining to get a good idea for what you're looking at around you.
This is looking east towards Panum Crater, which looks much more impressive from above than from the side (http://en.wikipedia.org/wiki/Panum_Crater).
You can see the lava dome in the middle, with the pumice ring, made of cinders surrounding the dome.
I wish we had time to look at it in person, but we had to find and meet up with our comrades to start our journey up to Wheeler Crest!
Sand Canyon Road more or less parallels Rock Creek and the nice paved road and campgrounds in the glacially carved canyon below. Sand canyon is a separate parallel canyon, higher up, that is made up of glacial till (loose sediments and rocks deposited along the canyon walls by the glacier as it moved down the canyon). We couldn't see to the bottom of Rock Creek, but the views of the surrounding mountains and peaks were pretty neat. At the time, we thought they were awesome, and they turned out to just be a warm-up to what we'd encounter once we climbed Wheeler Ridge. We took a break for lunch at the turn-off for Wheeler Ridge and then started the climb. :smiley_drive:
Here's our security, Audrey, anxiously waiting for us to hit the road again.
Although it isn't an especially long trail, Wheeler Ridge feels quite long because of the slow pace you make up the steep hills. At high elevations like these, the gas pedal isn't what it used to be, and you find your boot into the carpet more than you'd expect. It all adds to the experience, though, because it gives you a sense of how far up and away you are; that you're in a completely different place that most people never see. Anyway, there are some rocky outcrops and steep switchbacks that add to the difficulty of the trail, and if you're weighed down full of camping gear, you'll feel it.
After a good climb, we came down into a bowl-shaped saddle with an unnamed lake and some sand dunes on one side of the bowl. We of course had to take the opportunity to enjoy the plush squishy ride the sand had to offer, as opposed to the bumpy rocky roads we'd gotten used to over the last couple days. This was a great spot to take a break from the trail and let loose for a bit.
We continued on, and a short time later we broke out onto the side of the ridge, where we could finally see down into Owens Valley below. At this point, it started to feel more like a mission to get to the top, and things got a tiny bit more intense. We could see how far we'd already climbed, and we could also see the top, where we wanted to go. This portion of the trail is on the side of a cliff, or at least a very steep slope straight down 4,000 feet to the valley below. It was really exciting, as I'd never driven a cliffside trail like that, but being afraid of heights, it made me somewhat tense and nervous. Adding to those feelings, the trail wasn't cut flat into the mountain, but at an angle that tilts you down, off camber, to the downside of the valley. Some of the rigs were really top-heavy, and I could see them leaning quite a bit in the wrong direction when they'd find a bump to climb on the uphill side.
How's this for a campsite? We just drove by, but it's gotta be pretty spectacular to stay there for a night or two.
In between the cliffside portions, there were several very steep sections of rocky switchbacks that were fun to climb. We climbed for what seemed like days, and we started to see rocks different from the familiar granite (limestone, shale, etc).
We spotted an old exploratory mine pit ~20' off the trail and decided to check it out. Brad and I are college buddies that met as geology majors, and have done many field trips together. So naturally we looked in the pit for a minute or two, then dove right into the talings to see what treasures they'd left behind. :archaeolo: We found some pretty incredible rocks filled with quartz, native copper, and very nicely formed garnets. There are definitely veins of some pretty neat minerals through here, as evidenced by the small mine pit we stumbled on.
tizzdizz
Geologist
Once we made it to the end of the trail, we were pretty awestruck by the views to the north, south and east. I can't really guess but we could see for miles, and it was such a beautiful clear day that every feature was easily visible. We were looking down on Bishop, Tom's Place, Owens Gorge and Owens River, and the White Mountains to the east. This is what I came here for. I had wanted to do a trip like this for several years, and now that I finally made it back to this area, it was so much more fun than I thought it would be. :bowdown:
Someone had the good sense to put an American Flag at the end of the trail, way up on the mountain. It was perfect to add to the feeling of grandness we were already having. It made for a nice photo-op too. :victory:
Here's a shot from the valley below of what we had climbed.
I'm pretty sure the American Flag is just on the other side of that peak in the center of this picture.
As we headed back down, we took in all of the views from the opposite direction, and I saw the things that I hadn't seen on the way up. I had some good music going, some great new rocks for my collection, and lots around me to take in.
(looks like something out of star trek)
We made it back down to Sand Canyon Road mid-late afternoon, and continued up that trail to an unnamed lake at the end. There was a firepit and firewood already there, so we made it our home for the last night. Can't get much better than this, can it? :1888fbbd:
We ate a TON of food, we drank a bit, we played more music, and made the best of the night. We were all pretty pumped from everything we'd done that day.
Here are the videos from Day 3.
teddyearp
Nice report and especially videos. I might have to go back down to my hated state of Cali and check out that area. Too bad about the old iron getting trashed. But on another note it seemed as though the Jeeps do better than the others.
mizzle415
Looks like you guys had an awesome trip. Also looks like Slickrock far more challenging of a trail. On our trip up to Wheeler, we made it beyond the campsite/lookout over the Owens Valley, but not up to the top. We ended up turning around at the second little valley. Nice report and videos to show others what these places are all about.
tizzdizz
Geologist
Hey guys, I lost track of my trip reports for a while, but I'm back now, and wanted to share the last bit of story for this trip. Wouldn't you know, I typed up the whole thing, copied links to pictures, etc, and then my computer froze for the first time ever, and now I'm back to square one. This time around, I'm just gonna stick with pictures for the most part.
So to recap, here's where we had just come down from. The top of Wheeler Ridge at around 10,000' as viewed from Owens Valley, about ~6,000'.
[/url]slick rock and mono lake 2012 - 0258 by tizzdizz, on Flickr[/IMG]
So the last day (Day 4) was a travel day, but quite a long one. First we broke camp, then split up and went in different directions. One jeep wanted to go find some Hot Springs to swim in. One jeep headed back west into the mountains to find the Wagoneer that we had left at our last trail, at Lake Alpine of HWY 4. I went with Whitney to try to find a Uhaul tow dolly so we could get his Wagoneer home.
[/url]slick rock and mono lake 2012 - 0252 by tizzdizz, on Flickr[/IMG]
slick rock and mono lake 2012 - 0253 by tizzdizz, on Flickr
Two towns, 4 hours and a speeding ticket later, we finally got back to his Wagoneer. Some pictures of the broken bits:
[/url]IMG_0603 by tizzdizz, on Flickr[/IMG]
Broken shock mounts
[/url]IMG_0602 by tizzdizz, on Flickr[/IMG]
[/url]slick rock and mono lake 2012 - 0259 by tizzdizz, on Flickr[/IMG]
Broken transmission bellhousing
[/url]slick rock and mono lake 2012 - 0260 by tizzdizz, on Flickr[/IMG]
Broken transmission mount
[/url]IMG_0601 by tizzdizz, on Flickr[/IMG]
Broken leaf spring
[/url]slick rock and mono lake 2012 - 0261 by tizzdizz, on Flickr[/IMG]
Trying to get the jeep on the trailer was tough. The tires were far too big for the built-in straps to fit around them, so we had to completely deflate them to strap the axle, suspension and tires down
[/url]slick rock and mono lake 2012 - 0267 by tizzdizz, on Flickr[/IMG]
Then we had to deal with this:
[/url]slick rock and mono lake 2012 - 0268 by tizzdizz, on Flickr[/IMG]
[/url]slick rock and mono lake 2012 - 0269 by tizzdizz, on Flickr[/IMG]
It actually took a lot of work to reposition the jeep in line with the axle and front suspension so that we could figure out how to strap it all down, since they were basically two separate things, barely attached to one another an
[/url]slick rock and mono lake 2012 - 0270 by tizzdizz, on Flickr[/IMG]
tizzdizz
Geologist
We got creative with the chains on the trailer and the tow straps that we had, and it seemed OK. So we proceeded with caution.
[/url]slick rock and mono lake 2012 - 0273 by tizzdizz, on Flickr[/IMG]
[/url]slick rock and mono lake 2012 - 0276 by tizzdizz, on Flickr[/IMG]
We stopped many times along the way to recheck and re-tighten everything.
[/url]slick rock and mono lake 2012 - 0277 by tizzdizz, on Flickr[/IMG]
[/url]slick rock and mono lake 2012 - 0279 by tizzdizz, on Flickr[/IMG]
What should have been a ~4 hour trip down the mountain home ended up being a 12 hour journey, moving at around 30 mph hoping to avoid the separation of the jeep from its axle and the trailer. It was a really, really really really long day. But man, it was worth it. What a trip. Dang, writing this all up has me wanting to go back out again!
I love these roadtrips.
[/url]Untitled by tizzdizz, on Flickr[/IMG]
tizzdizz
Geologist
Bonus Pictures! I found a bunch from the trip that other people took, and wanted to share them.
Slickrock Road. You can see the old pavement in a couple of these pictures. Hard to believe this was actually a road at one point.
[/url]IMG_0588 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0583 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0575 by tizzdizz, on Flickr[/IMG]
Going down the staircase
[/url]IMG_0294 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0561 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0546 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0535 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0529 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0517 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0512 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0511 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0508 by tizzdizz, on Flickr[/IMG]
[/url]IMG_2397 by tizzdizz, on Flickr[/IMG]
[/url]IMG_2395 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0507 by tizzdizz, on Flickr[/IMG]
[/url]camping1 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0502 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0481 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0482 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0483 by tizzdizz, on Flickr[/IMG][url=https://flic.kr/p/pNEWgE]
[img]https://farm6.staticflickr.com/5607/15624361300_f118431ea6_b.jpg[/url]IMG_0238 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0234 by tizzdizz, on Flickr[/IMG]
[/url]IMG_2388 by tizzdizz, on Flickr[/IMG]
[/url]IMG_2389 by tizzdizz, on Flickr[/IMG]
[/url]IMG_0593 by tizzdizz, on Flickr[/IMG]
WonaWarrior
