86 FACTORY HIGH TOP VW SYNCRO
getset
FACTORY WESTFALIA INSULATED HIGH TOP WITH DOUBLE PANE WINDOWS
ALL NEW WINDOW SEALS, DOOR SEALS, AND FRONT WINDSHIELD
1.9 AAZ TURBO DIESEL WITH AIR TO WATER INTERCOOLER
REBUILT TRANSMISSION DURING ENGINE SWAP WITH TALLER 4TH GEAR
TRIPLE KNOB WITH NEW DECOUPLER (ALL IN WORKING ORDER)
NEW DIESEL GAS TANK DURING CONVERSION
ALL FRONT STEERING AND SUSPENSION BUSHINGS REPLACED (BMS)
BOTH FRONT AXLES REPLACED (LOBRO UNITS)
LIFT SPRINGS (SCHWENKE) AND OLD MAN EMU SHOCKS
T3 ANTISWAY BAR AND DROPLINKS
NEW POWER STEERING RACK (VAN CAFE)
NEW STARTER (BOSCH)
15" SA STEELIES AND BFG'S
LEATHER STOW N GO SEATS
BURLEY HD HITCH
BURLY SWING AWAY
DIESEL HEATER
DUAL BATTERY SETUP (GO WESTY)
BLACK ABS INTERIOR PANELS
OFRAM LED HEALIGHTS
AUXBEAM LED SPOTLIGHTS.
OMNISTAR AWNING (MATE BY THULE)
LT MIRRORS
This van was imported from the Netherlands via Germany with no engine. It was converted to a 1.9 AAZ turbo diesel with air to water inter cooler. I purchased the vehicle 4 years ago and set about repairing and fixing the last few items to make it more reliable with sights on a full restoration down the road. After quite a few trips in it we have decided something larger fits our needs better. It was built with back roads and over landing in mind. Simple configuration to maximize space and comfort for 2 people. It can however sleep four quite comfortable with the upper full size bunk and lower queen trifold memory foam mattress. The lower panel behind the galley was replaced as well as the lower panel in front of the passenger rear tire. The sealant at the rain gutters was removed (that sucked) and resealed with Sika UV resistant sealant. Focus has been on mechanics and functionality not aesthetics, but it does look pretty **************! The Westfalia top is incredible and designed with structural members for the Vanagon.
$37,500 OBO. Can install rear stock bench if desired. Potential trades and cash? More photos here, and I will add to them as request are made. Thanks.
https://www.dropbox.com/sh/sozo8cfmkfsbvx9/AADyoIJJMrmtfNA2XG6Kzlgba?dl=0
rocksandtrails
