87 fj60 - $2500
Patman
Don't really want to sell her, but times dictate sacrifices. Planned on a slow build and fix as funds allowed. Was my DD until I got my Syncro. Now it pretty much just sits. $2500 or $2250 without the OBA. Located in Hollister, CA I would jump in it now, gas it up and drive anywhere
The Bad
Cheap repaint over some bondo (by the po)
Roof was used as a rack and has some minor bubbling starting on the driverside rear
Engine needs an manifold gasket (included in the sale), an EGR Valve, and a smog pump to pass smog.
Pan gasket and rear main should be done, but does not affect driving.
Clutch chatters when heated up, but not under normal driving.
Needs a front knuckle rebuild, very driveable, but needs to be done
Steering box leaks
The good
new Fan/Fan Clutch, Rad Hoses in the last 2000 miles. No cooling issues at all.
ac blows nice and cold
windows professionally tinted last year
new Track and Trail Parabolic suspension 3" (2 leaf front and rear, 3rd rear leafs included but not installed, good up to GVW) Less than 4000 miles
Greasable shackles and pins less than 4000 miles
5 Dean SXT Mud Terrains 33x9.50s mounted on factory steelies. Virgin Spare, 4000 miles on 4
spacers to allow running Tacoma 15x7 steelies (just never found any at a reasonable price)
Quickair 2 OBA system with 2.5" viaair tank
Pics http://s758.photobucket.com/albums/xx227/lphultin/87fj60/
Patman
PM's Replied to, a few more pics posted to Photobucket as requested.
Mileage shows is just under 205K, however last 4000 uncorrected with the 33's so a little higher
Here is the the only rust on the body, and there is none on the frame,
iStan814
