89 econoline, np435 4 speed, np208 t-case, quigly front clip.. fs / ft
Itsavanman
Loosing my shop space.. regretting selling my project, but really don't have a choice, once again, in a situation where I won't have the space to finish it. what it is. 89 econoline 1/2 ton, 128k miles, a few small rust spots here and there, nothing major, in the doors mostly, can take close up pictures of the rust if needed, frame perfect, floors and rockers perfect, brand new rebuilt cylinder heads on the motor with less than 1000 miles on the top end rebuild, brand new tires with the same millage on em, auto 2wd trans having issues, was shifting fine until the shift cable broke, tried to repair it, and it still won't shift right.. gave up as it was getting replaced with the 4 speed for the 4x4 conversion. pedal box for clutch is installed, needs the brake pedal push rod extension welded on one side, and clutch master installed. didn't get very far on the conversion, needs everything installed. comes with all the parts with the exception of a few small things to finish the van.
comes with just about everything to finish the job - and then some
new clutch
new flywheel
new clutch master
new clutch slave
complete quigly d44 front clip w/ drive shaft on a trailer
New process 435 4 speed
new process 208 t-case
stove
icebox
water tanks
sinks
some other assorted camper stuff if wanted
I would like to even trade for a Toyota Previa / van or vw van 4/5 speed preferred, but will consider a slush box I suppose.. might consider other 4x4's as well no major problems as after aug 1st I won't have anywhere to do large repairs, but little problems are okay, will throw in the 6x10 trailer (with brand new deck) in the deal if your van is worth more than mine.. PM me here. I am located in Massachusetts. I have a build thread going in the 4x4 van section for the description of the work already done.
flipstick
