89 PacMule (AT Style Trailer)
toygoose
SOLD!!! SOLD!!!
I have an 89 PacMule w/ VIN#, included in the sale.
-trailer w/ tongue box and marine battery
-Tepui Kukinam w/ annex
-15gl water tank w/ 12v pump and water heater/shower
-chuck box w/ stove and utensils, if wanted
-rear removable stabilizer jacks
A few more details that have been asked
1. It's a Marey instant water heater w/ Flojet pump.
2. Table stores on the left & slides into another receiver tube, the jacks store between table and trailer wall.
3. Bolt pattern is 6x5.5 Toyota & Chevy
4. The battery is wired to the BlueSea fuse block, which is wired to the multi port on the side of the box, nothing else.
5. I charge the battery at home before a trip, you could add a small solar panel to the tongue box.
6. The 2 tan/brown totes you see inside are what I use for misc supplies like the propane.
7. It is spring under and could be flipped if wanted.
8. This is spring under suspension.
9. trailer coupler height is 21"
10. With the 2 rear jacks it is supper stable with the tent rack up and unhooked from the tow vehicle.
11. Track width is 64", tracks great behind the FJ.
12. When I purchased the trailer there was no tongue box or water tank. A fabricator in CO cut the tongue added about 28", it was sleeved 8" on each end, plug welded, and then plated and welded on all 4 sides. It was done right and pulls straight and true.
13. I think the coupler could be cut off and the articulating hitch slid into place and welded. I really like this hitch, articulates well with out the ability to go 360 degrees.
14. It has a spare tire mount that uses the rear hitch. The tailgate can be opened by letting the tire mount swing down, the mount can also be removed.
This is a great trailer and I hate to see it go but, it's time to move on. When I bought the trailer 3ish years ago it was just the gray box that you see with the black lid rack, since then, it has morphed into what you see now. The tongue was lengthened about 28", the tongue box was added w/ battery and BlueSea fuse block, with a side quick connect power port. The RTT rack is all round tube and its rack raises 20" by the use of electric actuators. On the passenger side there are 2 "L" brackets to mount an awning. The tail gate can be opened w/ the tent up and down with just a slight raise of the lid. The rear jacks and side table use 2x2 receiver tube and slide into place. The trailer does have the stock leaf suspension and rides very nice.
Please PM me with any questions.
Price: $6,000 obo not interested in trades
Price Drop: $5,500
colorado matt
ok I will go .... pic of the water heater set-up .... where does the table shown store in the trailer .... wheel bolt pattern .... is the battery wired just for the lift mechanism or any lighting ... how does the battery charge ?.. how do you carry your propane for the hot water .... is it spring under suspension .... what is the height of the ball when trailer is level ....is it stable when tent is raised and not hooked to tow vehicle ...what is the track width (sorry cant remember the right term for that ).... could you explain a little more about lengthening the tongue ..... would it be easy to add a articulating hitch........ ....... and the offer .............. 81 fiat spider convertible ... wish I had the cash .... seems like a great little package ..... Matt
toygoose
More Pics
Here are a few more pics from CO Matts questions.
