8900$ LOW MILEAGE '08 CRD Grand Cherokee WK, QDII, leather, sun roof, well maintained
msowka
LOW MILEAGE: 110k miles, lowest on the local market! It was my daily driver for 3 years, and would keep her if I didn't get lucky with a new vehicle. GDE tune was installed at 80k miles, and powertrain is bulletproof, note the fresh transmission lines & double flush! Admittadly I nor this vehicle have much cred on this forum, but did lurk here admiring others work (this CRD in partciular: https://expeditionportal.com/overland-classifieds-2007-jeep-grand-cherokee-crd/) with aspirations to build an proper CRD Overland vehicle. Failing that, I figured I would post the ad here in hope someone else would run with it!
I'm north of the border in Ottawa ON, but will assist with delivery & required paper work into US, closes crossing for me at 13669. I have Carfax available, and will disclose that it shows an incident in 2012 with no details, ie likely a bumper stumper and I saw no indication a collision in my maintenance of the vehicle.
Looking for a good Jeep / Diesel home! Not for parts! ?
Just now:
  • New High Capacity AGM battery
  • $$$ BOTH front end lower controls are (bushings!), left tierod, stabilizer links, aligned
  • $$ Bilstein 5000 series rear shocks
  • $$ Replaced diesel tank skid plate, new tank + 2nd SPARE tank! (none to be had from Mopar!)
  • $$ Front & rear breaks, including OEM calipers, rear ebrakes rebuilt
  • $ Turbo charge pipe temp sensor
Winter 2022:
- $$ New belt tensioner & belt, and $$ turbo resonator damaged in thrown belt
Summer 2021:
  • $$$ Transmission coolant lines, transmission pan & filter, DOUBLE flushed fluid
  • $$ front right knuckle
  • $ power steering lines
Required TLC:
- Rust on the inner rocker panels is creeping in, with three perforations now. Overall length of the pinch weld still in tact, and outer rockers still good. Rear subframe with surface rust, but solid.
Green Diesel Engineering tune, with all emissions intact, 8-9L/100km. Tuner included. OM642 are bulletproof.
THREE sets of tires: NEW Michelin Latitute, LINE NEW Wrangler Duratrac, and dedicated winter tires on steel
Negotiable, serious offers only
  • Like
Reactions: WVI
gp01
