90' Dodge Steering Question
wagoneercraig
Is there any way to swap out the steering coupling at the steering column and steering box ? The one i have is very sloppy and the design appears to be problematic .And yes i have rebuilt and replaced the foolish thing just about every year . Now I had once seen a U-joint style coupling but it has since disappeared off the market . Any ideas would be great
pulltilbroke
You could pony up the cash and buy a Borgenson shaft or take the original shaft and weld a joint on the end like I did on my 90.
lowenbrau
I think the factory one was designed for a Coronet or Dart or some other light vehicle with nearly no angle between the shaft and the box. They just don't hold up well in a truck. That being said the replacement joint costs less than an oil change and takes about as long to swap out. I just can't justify spending the big bucks on a Borgeson shaft. I might just chop the shaft and weld on a Spicer joint someday.
Metcalf
The steering column joint from some Chrysler FWD cars works as a great replacement. Perhaps a New Yorker? Its a normal u-joint style unit....
SRMN8R
Go with Borgeson joints and some double d shafts. That's what I replaced my 55 Chevy truck steering shaft with. No slop, stainless steel, and it'll last forever. It's a very cost effective set up too. I spent maybe $150 on everything. Remember to use loctite!
wagoneercraig
Thanks for the intel . Hope all of you had a great Holiday . I like this idea and i'll check it out . Thanks . I like simple and clean . I wouldnt mind cutting the shaft and grafting the joint on . But buying box's is little to much for me . This truck needs a lot of love and time is scarce .
ColoradoBill
Borgeson all the way!!!! I have used them on my Dodges, they work great. They are pricey and worth every penny. They only take 15-20 minutes to change. After you finger in all the time it would take to scab together a new shaft you would be money ahead with the Borgeson.
Just my opinion.
wagoneercraig
I hear ya , Maybe later this year . But i was really hoping for something simple . My truck is loving the purse strings this month
wagoneercraig
Ok . I hear you loud and clear . It's always better to do it right than rigging something . Just finished replacing all the bearings ,ujoints . So suspension and the Borgenson after the holidays
wagoneercraig
There arent any pics of my Dodge truck yet. After years of neglect it has proven incrediblely reliable. So im going build it up. When i get further along i'll do a build threIMG_0536.JPGIMG_0537.jpgIMG_0536.JPGIMG_0537.jpgad . But there's a build thread of call the "Birth of the Wandering Wagons " under my web name . But i just sold the Wagoneer .
Clemtiger84
