'90 Grand Wagoneer - Southwest IN
IllianaXJ
Listed my 90 GW on eBay: http://cgi.ebay.com/ebaymotors/ws/e...348576685&viewitem=&sspagename=STRK:MESELX:IT
Basic rundown:
* 1990 Grand Wagoneer
* 160k
* 360/727/NP229
* D44s F/R, rear LSD
* Tow package (factory hitch/wiring/trans cooler/3.31 gears)
* Rusty's 4" Full Spring Lift w/ shocks - installed June 09
* 31" Goodyear Wrangler ATs - 40% tread
* Warn standard locking hubs
* TFI ignition setup w/ 8mm MSD wires
* CS144 alternator
* 180* t-stat
* Factory block heater
* All new exhaust from manifold back - cat delete/Prosound muffler/tailpipe
* All smog junk removed/unnecessary vacuum lines removed
* Oil pan gasket/valve cover gaskets replaced. Still leaks a bit from the oil pan
* Replaced dipstick tube with Bulltear tube
* Fresh oil change with Delo 15W40
* Excellent oil pressure - 60 PSI cold, 40 PSI hot idle around town, 30 PSI hot idle after highway use
* New oil pressure sending unit
* Rear window works from dash switch, key switch disco'ed
* Electrical temp gauge mounted under dash/CJ style tach in dash
* Kenwood CD player
* Interior in GREAT shape, no rips/stains with the exception of rear cargo panels
* Newer headliner
* Overhead console w/ compass and temp
* WalMart minivan console
* All windows/power locks work
* Minor rust on rockers, random spots on doors
* Gas tank rust previously repaired
* Rear wind deflector waiting to be installed
* All 4 center caps in storage, good shape
* Front/rear trackbars also in storage
* I have a folder of receipts from the PO with tons of dealer service
More pics on the auction listing.
