95 disco 1..worth it? problematic?
evilfij
This they all leak oil is sort of overblown. If you replace the cross seals with the new style, make sure your end seals on the intake are properly seated, and keep your PCV clean, it should be relatively leak free. The rest of the seals (HG, intake, valve covers) tend to weep at worst.
crimson850
So with what I have mentioned above is their anything else I should do or look for? It runs great! I did start it earlier and it cut off after a second but fired right back up and ticked right along!
dhuss
