I very recently spent a LOT of money having the crank pulley replaced on my 95 LS due to it wobbling and being loose. While it was apart, I had them replace the water pump, timing belt, tensioner and idler pulleys, the crank angle sensing blade ( 'cause they bent it getting the old pulley off, and I knew enough to order it and have it on hand ).
It has been a few weeks, and once again, the crank pulley is loose and wobbling. I took it back to them near closing time yesterday evening, where the tech who did the work said that he thinks either the dowel pin broke, or the pulley is coming apart. He says he torqued the bolt to 135 ft lbs, and he used the new bolt and washer that I supplied. I also supplied a new key for the crankshaft, which was not installed. It should be noted that all parts except the water pump and tensioner were Mitsu parts from Southwest Mitsubishi. I asked that the old parts be kept for me to take home, but when I checked the box last night, the old pulley was not in the box, so I don't have one handy to measure myself.
So, since I supplied the failing parts, the shop is not going to honor the warranty on the job, as far as I know at this point.
The questions I have:
Does anyone have the ability to measure the distance center to center, between the 2 holes that are used to stop the engine spinning when torquing the crank pulley bolt, if they have an old one laying around? The mitsu part number for the pulley I need the dims on is MD368262. I am hoping that the bolt simply backed out a bit and can be re-torqued to fix it, but they do not have a tool to stop the motor from spinning. I am in talk with a guy who sells various tools on eBay but he needs the dims of the holes. Also, are the holes on the outer face of the pulley or are they set down in the deeper well of the pulley?
Does the key that is shown in ASA for the crankshaft also help keep the pulley from moving on the crankshaft? I ask because as I said, they did not use the key that I supplied, and I'm wondering if they did put it back together without a key, if that would be part of the problem?
I realize that these questions are elementary for most of you folks, and for that I do apologize. I am not very mechanically inclined, nor do I have the facilities or tools to do this stuff myself, as much as I want to. And apparently, there isn't anyone around here who knows the finer points of working on these trucks.
Once again, I thank you all in advance for your input and time. It is very much appreciated.
MJ
MJ
