'95 White on tan LWB w/ 170k miles. In very good shape. NO rust. AC and heat run fine; engine runs strong and smooth. Coil conversion with HD springs
New (all within the last year): headliner; Cooper AT tires; upper tailgate; rear window regulator; Window ECU; pads and rotors; valve cover gaskets; driver's door handle; hoses for AC, heater and breather; ignition wires and plugs; damper and track rod and tie rod ends; ; Disco drive shaft and flange; swivels seals; alternator and more.
$4,000
http://s261.photobucket.com/albums/ii66/Gventure/
$4,000
