95 tahoe "blue bus"
the blue bus
started working on it when i was 15 before i could drive. was all stock when my dad had it. last summer did a 3inch body lift to it. then over winter break did 2inch block and crank.has 15 wagon wheels with crappy 33 bfg all terrains. almost time for new tires. has straight pipe too. done a lot of mods too it over the past year
-cobra 19 with pa whip on bumper
-blue led guages and door switches
-white leds rest of interior lights
-clear cab lights
-tyc headlights and clear corners and parking lights
-ddm 4500k hids
-diesel bumper with lights
-aux reverse lights
-installed overhead console
plan to get some switches up in my console. add some rock lights under it. no rocks here but help in the woods at night and in fields where we mud and stuff. blue leds in door handles that light up with inteior lights and when you unlock it. get tow mirrors on it and lift keys to level the front and maybe swap to a 3inch block. need to find some 33 mud tires for it too. need to clean up my wiring under the hood and make a relay box and add a fuse block under the hood so i have a place for when i add more lights. it may look clean in pics but shes got scratches all over and is no street queen. had her burried more than once lol long *** nights crazy storys too. have a lot of pictures but will start with these for now
in the beginning..
currently
interior..
not as purple as camera shows. ac controls headlight switch and door swiches leds are on order
console
needs some cleaning
the blue bus
going to radio shack to get the box tomorrow to put all my relays in and get a fuse buss too for the box. have a few questions about the wiring though. for the switches in the console can i dasey chain all the power wires together down to the fuse panel in dash like im going to do the ground wires? that will make less wires to run down the a pillar. also when i go to junk yard this weeknd going to put some weather connectors on all my lights to make em removable and have 14g wire to use on the front lights. may upgrade them to hids later on. what guage wire should i use running from the battery to the fuse buss? started to mock it all up tonight but its dark now to take pictures. going to run all of the signal wires along the firewall to the box by the battery in wire loom. you will hardely notice them there.
flipstick
