98 Tacoma Regular cab supercharged $8500
98tcoma3rz
98 Tacoma regular cab 2.7 4x4 230k miles
Excellent mechanical condition. Very well maintained. I purchased from the original owner who had it serviced every 5000 miles at Toyota. Frame is excellent.
I have the original window sticker as well.
Everything below has been done within 30k miles
Lower ball joints, inner and outer tie rods, radiator, rear wheel bearings, crank seal, all OEM.
Head gasket replaced by Toyota around 200k miles.
Trd supercharger just installed 2000 miles ago (low boost) (valve clearance check and adjustment done at same time)
33x10.5 BFG KO2 with full size spare
Northwest offroad header with Dynomax cat back exhaust. Flwmaster stainless cat
Front and rear ARB lockers with 4.88 gears setup by just differentials
Front icon extended travel coilover with spc upper control arms. literally just installed 100 miles ago
Extended inner cv boots
front diff drop
Rear old man emu Dakar with add a leaf, OME shocks, OME greasable shackles
Allpro u bolt flip kit
Front trail gear bumper with superwinch LP8500 winch
RAT front skid plate
Rear trail gear bumper modified with swing out tire carrier and fuel can holder
Rear frame boxed
4x innovations sliders welded
Rear diff guard welded
Smittybilt defender roof rack
There are much more modifications done. So many to list but these are the major ones.
Rear fender is starting to bubble a little bit (rust) Body has some scratches and small dings. Interior is excellent.
$8500 O.B.O Located in Lancaster, pa
DisGRUNTled0311
98tcoma3rz,
Beautiful rig, do you happen to have any pictures of the undercarriage, Interior, and the rear fender that is showing signs of rust?
Thanks in advance!
Babbert
