ABS/wheel speed sensor. OEM or aftermarket?
I did do a search but didn't find anything specific. Other forums are mixed. The OEM sensor for my 1998 is around $260, aftermarket can be had for $10-$30. I found a unit on Amazon made by 'Performance Parts Network' for $28 shipped. Anyone have any experience/opinions either way?
Salonika
Monterror Pilot
IMO it depends on how soon you want to replace it again if it fails. If you value your ABS system and consider it to be safety related, get the Mitsu one. Not to mention the job is a PITA if you have to extract the old one. Here in Michigan the first thing that happens is you'll break the sensor bolt off. Then you'll need to use a bur and dig out the sensor itself. Not the job I want to do every 3 years.
