AC Compressor Bearing
PirateMcGee
Is it possible to just replace the bearings in a 6G74 AC compressor? Mine is starting to make some noise. Compressor works just fine it just seems that the front bearing is starting to be a bit worn out.
nckwltn
Yes, I've pulled the bearing off.. it isn't an interference fit, so you can unbolt the pulley and slide the pulley and bearing off. But you need the compressor out of the car to get the right working space.
Sent from my A0001 using Tapatalk
Salonika
Monterror Pilot
I just put in a new compressor yesterday. About a 3hr job, it comes out the top, you need to pull battery and tray.
nckwltn
Thanks. I was hoping to avoid pulling it out of the truck but maybe that's not possible.
There just isn't leverage to pull the pulley and bearing without perhaps removing more from the front end (radiator, bumper, etc)... you might get lucky and have it come off easily, so worth a shot.
Sent from my SM-P580 using Tapatalk
