added some removable Core Trax to my bed rails using photography brackets
Jeepin_D
Damon Bungard
I posted this on 'my 2016 Rebel build' thread in full-size RAM trucks but wanted to share here as well since it's applicable to any truck build.
My DECKED system came with the Core Trax adjustable load tracks but I decided against permanently mounting them to the flooring since I slide things around back there a lot and the tracks would stick up enough to get in the way. I wanted to mount them on the side of the bed, but I didn't want to drill through the sidewall.
Eventually I found these photography brackets on Amazon -- Julius Studio C Clamp Multi Functional Adapter.
https://www.amazon.com/Julius-Studio...+mount+adapter
Basically similar to the C-clamps used to hold down a truck cap, but drilled and tapped. Bought a few of those and some 1/4-20 stainless flared head bolts and voile, removable side-mounted Core Trax.
3 clamps per side and it's a pretty rigid setup. I wouldn't mount something like a Hi-Lift to these, but for organization to keep things from sliding, should be great solution.
