K2ZJ
LONG time ago I added a 7 pin connector to my Jeep Grand Cherokee so I could use a trailer to move to Colorado. Since then the wiring/connector has fallen/ripped off my Jeep and I have also added a custom high clearance steel bumper. The bumper uses the stock hitch mounting which is the same as the gas tank skid plate. I am buying an off road trailer that has brakes so I need to add the 7 pin connection again. I want to keep it protected by putting it though the bumper up out of the way. The problem is how the 7 pin plugs connect and mount, you put wires through the hole and the plug mounts on the outside. How would you suggest I connect the wiring if I need to drop the bumper for any reason without cutting and splicing wires? Or do you know of a connector that can mount to back?
