I have a no-name fiberglass 8' cab-over camper that uses 4 crude pistons and CO2 to raise a heavy fiberglass roof. In order to conserve CO2 I would like to add gas struts to my camper and I have an idea of how to go about it but just want to confirm my idea with those who have completed the mod. By adding the struts I'm assuming it would require less CO2 pressure and therefore my 10lb bottle will last longer.
1. Weigh the front of the roof, in the center, where I plan to install two gas struts using a 2x4 propped between the roof and a bathroom scale.
2. Weigh the back of the roof where I plan to install two gas struts as described above.
3. Divide front and back weights by 2 since I'm using 2 struts in each location.
4. Select struts with less force than the divided front & back weights so the top will close under it's own weight.
Example:
Front weight 140 lbs / 2 = 70 lbs use (2) 60lb struts
Rear weight 60 lbs / 2 = 30 lbs use (2) 20lb struts
I may be way off, if so please let me know.
Thank you
Example:
Thank you
