Herbie
Rendezvous Conspirator
Has anyone found a good solution for adding a more robust padlock hasp to a Pelican style case?
I have a Storm im2720 that lives full-time on the rear-door of my van, and I keep enough stuff in there that I like to keep it secured whenever possible. The case includes provisions for a small padlock, but the holes are small and just the plastic material (not reinforced with a steel ring like the main-line Pelican case hasps).
I've also gotten tired of replacing rusted padlocks, so I switched to a set of fully coated locks, so my padlock shackle is even larger diameter than normal because it has a rubber cover and an O-ring gasket. These shackles are just too big to fit the stock holes, and there's not a lot of material there to make enlarging the hole practical.
Ideally, I'd just rivet on an aftermarket stainless steel hasp to the box, but the design of the box with the "flanged" lip makes it so there aren't really to parallel surfaces to attach the hinge and hasp to.
You can see the "flange" and small hasp-holes here:
Looking for any ideas, or unique hasp solutions to let me put a regular-sized padlock shackle on this thing. Thanks!
