Adventure trailer battery
Tiguy
Hello everyone,
I have an adventure trailer chaser. I just purchased it used and am getting a beeping in the battery compartment.
I have it plugged in to 110v and the digital gauge shows 15.2v. I cant figure out why I'm getting this beeping?
Has anyone had this issue?
Thanks
228B
I am not well-acquainted with that particular trailer.
Do you know what brand, and type battery it is? 15.2 is kinda high, unless it's being put through an [cell-] equalization phase... definitely too high a voltage for a sealed, AGM battery in my experience.
Martyn
From standard equipment fitted in the nose box you shouldn't be getting any beeping. The battery is not the original brand, and apart from a digital solar controller nothing else we would have put in has an LED read out. Leads me to believe that what ever is making the noise was fitted by the previous owner. Send or post up pictures of everything electronic in the nose box so I can see what's going on.
15.2 volts is a high charge rate. The only thought I have is if the digital read out is on the battery charger it could be an overcharge warning beep??
fa1na
I have seen this kind of voltage while running a desulfator in parallel with a not so smart charger
Inviato dal mio GT-P3110 utilizzando Tapatalk
Goldenbora
