Adventure Trailers Horizon for sale
cwvandy
Horizon Trailer SOLD
1) Lightly used, 2010 perfect condition Adventure Trailer Horizon (no exterior scratches, dents, dings): always garaged
2) All available factory options including Tass Suspension, drop leg jack and floatation tire, rubber matting, cargo tie downs, tread plate fenders, roof rack cross bars, 2' accessory receiver (front and rear), 7 pin wiring harness installed, stabilizer
3) Max Coupler hitch w/ removable extension
4) Steel Powder Coated Nose Box with Rhino guard leading edges
5) 2 non-CARB Fuel Cans (5 Gallon) and AT Holders (CARB compliant cans available if you want them)
6) TWO 19 Gallon Roto-mold water tanks with manual and electric pump (second tank in box and plumbed with shutoff value to outside tank)
7) Kitchen-two burner slide out stove, TWO 11 lb. propane tanks, cutting board, SS sink
8) Custom wood drawers in galley above stove
9) Auxiliary 12 Volt Power wiring with back up light, 4 Fused Outlets, LED lights in main and side boxes
10) TWO AGM group 31 batteries
11) Xantrex Freedom HF Marine grade 1000 watt inverter and charger
12) Blue seas 12-volt amp hour and voltmeter built into nose box
13) 110 watt solar panel w/ cover in custom storage bracket under roof rack (solar controller hard-wired into electrical system)
13) 6x6 Awning F-35 and telescoping brackets mounted on box
14) Front Pull frig slide-out slide, New National Luna 50 Liter Stainless Fridge w/ thermal cover
15) Electric Braked 10” drums
16) Brand new (3 miles) Toyo Open Country AT2 tires--285 75 17---on brand new Tundra TRD Rock Warrior wheels (plus brand new wheel bearings and seals)
17) Second set of hubs with Tacoma bolt pattern
18) Heavy Duty 0 gauge charge cables to vehicle w/ Anderson plug
19) Auto Home Air Top not included but will negotiate if this tent is what you want
20) Issues/problems: None. Some minor paint scuffing inside side boxes from items moving.
Over $20K+ invested, Asking $13K
Located Bend, Oregon
Photos below (more on request; Portal limit is 10)
cwvandy
Additional Photos for Horizon Trailer
More photos for trailer.
AML
This looks new! If I was in the market right now I would jump on this. Unfortunately I have to wait. GLWS
Big mike
Wow nice trailer at great price. Someone is going to get a great deal on what looks like a great rig!
GLWS
MIKE
