Advice on trailer hubs
geanes
ust bought a Morris Mule knock-off with the Timbren Axle-less suspension. The builder put on the Northern Tool 1750lb hubs. These are supposedly their highest rated hubs. On Thursday, I swapped out the 27" tire/wheel combo with my 33" tire/wheel combo. On Friday, while driving on the highway, I heard a weird whining noise. I pulled over and, as I turned into a parking lot, I noticed the right trailer wheel wobbling. I got the trailer jacked up and the wheel was complete loose on the spindle. I finally got the castle nut free (remains of cotter pin were still there) and removed the hub. There were no bearings anywhere, 1/8" of grease lining the entire inner wheel, no bearing carriers and the races frozen/welded to the axle. I called Northern Tool and was told that their hubs are only recommended for standard trailer tire/wheel combos and not the larger/heavier off-road tire/wheel combos. This is distressing as I bought this to be an off-road trailer. I have to order a new axle assembly for the right side as mine is gouged and scoured pretty good plus the races are welded to the axle anyway.
Doe anyone have a recommendation for off-road hubs? What is everyone else using?
Thanks for the info.
Need to be strategic about where you try saving money.
Please let is know how the Timbren knockoffs fare!
nahuebsch
