RoundOut
First some background... I recently purchased a Viair 400C compressor and enough fittings to outfit a 4 bay garage (not quite, but that is what it seems like). I am relocating my batteries to the rear behind my differential under the bed and plan to locate my compressor where the stock battery was in the front left of the engine bay. I have an air tank, which will be right behind the batteries under the bed. With the rear lighting, relocated batteries, backup sensors, and compressor, I have (or will have) no less than 8 cables from 16 gauge to 2/0 guage, plus an air line.
The air line that comes with the remote mounting kit that Viair sells, is a black poly line of some sort. I have similar line on my home's swimming pool chlorinator system and it becomes very brittle over time (a year). It gets sun only in the afternoon, but is exposed to chlorine gas constantly, so maybe that is why it doesn't last more than a couple years.
I plan to have quick connect couplers for air accessories at two opposing corners of the vehicle, for ease of airing up tires and helping out others. The pressure switch I purchased cuts off at 150 psi and comes on at 120 psi. Therefore, the pressure in the line will always be at least 120 psi. I am having trouble imagining the poly line lasting more than a few years without failure.
The check valve will be at the end of the braided leader, right before the manifold. Near the compressor, I'll have a pressure gauge off the manifold, plus a line to a front quick-connect, a pressure gauge line serving the gauge in the cab, an overpressure relief valve, plus the main line to the tank. Before the tank in the rear, I'll have another tee to a quick connect for the rear. Everything between the compressor, quick connects and tank will be at 120-150 psi at all times.
Now the questions...
- Is the black poly line that comes with the remote mount kit a long-term solution?
- I was at O'Reily's tonight and discovered hydrolic line, which is similar in I.D., but has braided steel reinforcement. I love to overbuild stuff to assure less repairs, so what do you think I should do? Use the poly line or go for hydrolic? It won't be more than about $50 for the hydrolic line with professionally crimped ends.
