Air line setup
206WJ
So I have a question about running new air lines.
I currently run a viair 200 PSI 5 Gallon dual compressor OBA system. I love it, but the only issue i have is needing more locations on the rig to connect to. I have it all mounted in the spare tire well, so I don't have any dirt or water issues with it, but with the rear bumper it's a pita to open the rear hatch when I just need some quick air.
My question is what type of lines should I use to plum it to the front and back of my rig? I would love to use something small like hard wired brake lines, but don't know much about pressures and air leakage. Any thoughts, tips, suggestions?
Jakes01234
i use the plastic line that viair sells with there kits.. i havent had any breaks in the five years its been installed.. I also had luck with the arb lines...
Cant find a link to the viair stuff but i did find the arb stuff..
http://www.4by4connection.com/arbairlocrep.html
I just remembered i bought the black line from the local hardware store..
Jim K in PA
You can certainly use steel hard lines (like brake lines) but be sure to use something with at least .25" diameter or larger to ensure adequate air flow. I plan to use the DOT air brake lines used on large trucks. You can get the line and fittings for good prices on line via ebay, et al.
I used 3/8 copper lines in my Land Rover. I had the plastic but when the kids kicked the ones under the front seats they leaked. No problems with the copper line and they've been in for almost a year. I just used the 45 degree flare stuff for all the joints. I would give the air brake stuff a try first, it would be alot easier to work with. Here's a pic of my setup
206WJ
Thanks guys! I am going to look into the air brake lines. they seem to be cheap, and should hold up to my 200psi setup.
