Air quick disconnects
gonejeeping15
I installed some air quick disconnects in my water lines on the trailer and noticed the water turning rusty color. My well water guy suggested I use brass ones, so I replaced them only to find they have steal bearings inside, more rust.
Is there a fix for this or should I just eliminate them?
thanks
Titanpat57
The biggest problem is that the the balls in the brass coupler should be SS...and there NOT......just cheap, made overseas garbage.
The rust will not last long in the running water.....but the fitting will inevitably prematurely fail.
r_w
several SUPPOSEDLY all-brass options. Most have standard steel ball bearings and springs--they shouldn't be in contact with the water but it still gets rusty.
There are ALL SS options, but they will cost you....
