air suspension fun and games, LR3
Jwestpro
Posted by member StreetsofCompton: "Does the IID tool allows for independent adjustments for each corner, or just F and R as two separate units?
If my front is indeed a hair taller, is this something to be overly concerned with or could it be a simple adjustment? "
The lr3 usually has a higher rear. If yours is lower in the rear, there's a problem but I';d look at it on flat/level surface before worrying. "465F/485R" sounds like a rough axle center to fender edge measurement while in standard EAS height on an lr3
Clemtiger84
