Superu
Offered for sale is my Air Zone 4 person tent that has only been used twice indoors. With the size of my family and limited time available for excursions, I simply don't have the time to make use of this tent so I thought I'd make it available to someone with more time and/or a smaller family!
It is identical to the AirZone Osprey with the exception that this one uses a slightly lighter weight fabric. This was part of a special order run created by AirZone. The tent includes a hand pump and small extension hose, but you could inflate it even more quickly with your onboard air, portable compressor or CO2 canister.
Here's a pic from the AirZone site highlighting some of the features.
And a link to some demonstration videos as well.
The heavier weight fabric Osprey retails for $699. This model new went for $499. Offered here for a very reasonable $250 shipped to lower 48.
Setup and breakdown of this tent is super quick. The rapid setup time is invaluable when the weather turns suddenly or if you arrive at your destination in the rain. Those extra minutes setting up a conventional tent can mean the difference between being a bit wet and being soaked through to the skin. Additionally, the freestanding nature of this tent means that you can set it up without stakes if you needed to. You could inflate it, set the fly and climb inside until things let up and then go stake it down if you wanted to.
Specs below match the actual tent being offered.
Model: 76-5051-8
Style: Full Fly Dome with Vestibule
Floor: 9' X 7'
Height: 68"
Weight: 16.5 lbs
Capacity: 4 person
Fly Type: Full coverage fly with two stake-out vestibules
Tent Body: Polyester Rip-Stop PU/FR 1000mm & Mesh
Screen: Nylon Mesh
Floor: Bathtub Design, Nylon Oxford 1000mm with seam tape
Fly: Nylon Rip-Stop PU/FR 1000mm with seam tape
Inflatable Supports: 2 Marine Poly Air-Poles
Pegs: Steel 4mm x 7.5"
Zippers: YKK Nylon Coil Zipper
Door: Dutch "D" Style Door, 2EA
Bag: Duffle Carry Bag with embroidery Logo (Nylon Oxford 210D PU)
Windows: PVC Windows with inside Privacy Flaps
Quick Clips: Side-Release buckles
Intake Valve: Standard Automotive
Pressure Valve: Prevents over-inflation
Model: 76-5051-8
Floor: 9' X 7'
Height: 68"
Weight: 16.5 lbs
Capacity: 4 person
Screen: Nylon Mesh
