1977 M886 Ambulance - Dodge W200 318 2b AT 4x4
Dana 60 rear axle, Dana 44 front axle, 4.10 gearing. MileMarker manual lock-out hubs and part time kit in NP203 transfer case upgrade from full-time 4 x 4. New hub bearings installed at time of MM kit install. 65964 miles. Ambulance body gutted out to bare walls. Has pass-thru door to cab. Receiver hitch installed up in frame to allow use of rear step and better ground clearance.
Engine crankshaft has end play, so it was deadlined. Rims & tires will be replaced with original 16.5 setup. Cab has a dime sized rust thru at bottom rear of drivers door opening. Contents is NOT included, photo is just to show door opening width.
Would make a good foundation for an expedition camper.
$1400 picked up in Henagar, AL. Northeast corner of state.
256-599-498six
http://huntsville.craigslist.org/cto/4351467104.html
256-599-498six
