All purpose trailer
Coopsdaddy
This is a new trailer i built over the summer that turned out way nicer than what i ever expected or needed.New,never out of garage other than trial tow of about 20 miles and never in weather.I built this to pull behind 4runner or tacoma and wanted a all purpose trailer were some seem to be lacking.With the awesome examples of craftsmanship on here I copied a few to build my own.It is built to haul camping gear,kayaks,awning,roof top tent,as well as be a utility trailer when needed to haul lumber,sheetrock,4wheeler etc.
It is built just wide enough to slide a full sheet of plywood in with tailgate down and just long enough to sleep in if needed.
All receipts and pics.All mig welded,sand blasted,seams sealed,primer with self etching primer and commercial bed liner applied(not cheaper self applied stuff).
Pulls great and looks great,you will be hard pressed to find one this nice without the price tag of bigger companies.I didnt make a top but you could easily take off thule rack and build one on the flat rails.The mounting holes for the thule rack are drilled and sleeved so no water gets in top rail.Interior tie down points everywhere and tailgate will disconnect and drop all the way down if needed.Simple wiring and led taillights.No title and no title needed in Oklahoma.
Outside
L-79.5
W-51.5
H-23.75
Inside
L-77.5
W-48.5
H-20.5(bottom of top rail)21.5(top of rail)
Tongue height level-25
Ground clearance to bottom of bed-24
Max space between bed rails and bottom of thule bars 27-28
Weight-not sure but close to all the other trailers built.
16 ga floor and sides
1x3x14 ga top rail
1.5x16 ga square tube
2x3 tube frame and tongue pie cut and bent in to form one piece.
Sliding tounge for hauling longer loads.
6 lug Dexter 3500 axle with brakes
Toyota FJ 17 inch steel wheels and 255/75/17 bfg tires
Tailgate latches and cables
Bulldog jack
Powder coated tool box
Black lug nuts.
Coopsdaddy
Serious inquires only,i dont need to sale,im not on here much so text if you are interested.Pick up only.Cash only.I can keep in garage as long as needed with deposit.
I will sale with or without thule xsporter and arb awning.
9185955774
4500.00
3800.00 without thule xsporter and arb awning
Coopsdaddy
Thanks
Houie
