all terrain opinions
zukrider
i am wondering if any of you have any personal experience with toyo open country a/t?
im looking at either toyo a/t or bfg a/t. ive never seen or drove the toyo's. i would like some comparison info and experience to help me decide.
they will be going on a 91 burb, v1500, that will have 4" and end up with all the goodies1 i.e. bumpers, guards, winches, lots of gear and a whole family. i live in denver, so snow, rain, high temps, low temps, rocks, roots, etc.... i have a tendency to rock crawl, trail ride, etc... though i will be cutting that back a bit for this rig.
i tend to weigh heavily on tire longevity and performance. noise is not a concern
thanx for your input!
joe
Regcabguy
Oil eater.
Toyos.
My friend and I run the Toyo 285-75-17 AT's. Buddy's got an '07 CTD w/flatbed mounted Phoenix 9' popup and utilitiy cabinets. He's racked up over 1500 offroad miles on the coastal route between Miller's Landing and Punta Canoas. His rig weighs 12,000#. No flats or structural damage to the tires yet which is incredible. He just returned from a trip down there which was a major mudbath. E rated and a load rating of nearly 3900# each helps.
dbreid
XTerrain
I've had great luck with 35" Pro Comp XTerrains on my 2500 Suburban. They go great offroad, and I have piled on the miles on the pavement as well.
Capt Sport
I got Toyo AT's on my truck. I've got 25000 on em and they look great. I've driven on the beach with them aired down with no problems. Which is quite a feat considering they are the stock size on my truck, which is quite small. I'd buy them again based on their performance so far. So I obviously and confident in my recommendation of them. Oh and they are pretty quiet as well.
CodyB
I ran LT265/75/R16 on my Chevy K1500 extended cab short bed truck for the five years I had the truck. My biggest complaint was the tires would pack with snow and not clean out at times. When in the hills I would just put chains on and all was good. The first set I had I got 50,000 miles out of the tires. I did rotate every 3,000 miles. I did have the first set siped which resulted in a bit of chipping in the rocks on the edges of the tread blocks.
I then replaced the tires with P265/75/R16 because I needed a new set of tires for just a few months before I bought my Toyota. The P rated tires were much cheaper which is I opted for them the second time since I was only going to have the truck for a few more months.
zukrider
thanx for all the input guys. ive changed up the planning for now and just picked up 2 new 265/75-16 BFG A/T for the front to match the ones ive got on the rear.
when these go dead, then ill do the lift and 35's
joe
19psi
The Devil Made Me
check out the General Grabber at 2's. they're fantastic, better than the bfg at's.
Clemtiger84
