Alternatives to standard air quick connects?
jsmoriss
Hi everyone,
I have some 150psi outlets in my Jeep for airing up tires, and eventually will have a 90-100psi outlet for air tools as well. I find the standard air fittings very difficult to connect under high pressure. I know there are many non-standard air fittings that exist, and I'm looking for suggestions. I don't mind spending a few bucks for quality fittings that will last a lifetime.
Thanks,
js.
soonenough
Not sure if this is what you're looking for, and I have no idea if any of these are easier to connect/disconnect than others. I thought I'd post it for reference, since I've found it pretty useful for identifying odd-ball couplers in the past. BTW, sorry for the huge pic, but when I resized it to make it smaller, the print was barely legible.
M.Bas
How about those things found on trucks? (plug em in and then rotate to lock)
Will try to find a pic of them....
I Leak Oil
Just install a ball valve before the female end. Any of the QD's will start to leak after a while so you'll be ahead of the game anyway.
Jason T.
jsmoriss
Jason T.
Thanks for the suggestion. This is actually what I started doing, but wanted something a little nicer. I dug up an 'auto coupler' from my spares box which is really nice -- the sleeve stays retracted and pops back when you plug into it. After looking around a bit, it seems the Tomco is even better, with an on/off and purge feature. They're a little pricey, so hope they're worth it! :)
js.
DanoWall
