Noticed low voltage on the gauge last night. This has happened before, just a month or two ago. I thought I solved the problem by cleaning up some terminals. I had dimming lights at idle, slow wipers, fan, etc. Everything improved after a little cleaning, even though nothing looked very bad. Last night though the gauge went lower than it ever has before. So I broke out the multimeter and hooked up wires directly from the battery, and verified the gauge reading. It was down near 11 volts. Crap. Decided I might need to take another look at what I did before, maybe I missed something. To my surprise this morning when I started truck both gauges went up to 18.6 volts. Then my ABS light came on. I shut the truck off immediately and started doing homework. I believe my voltage regulator crapped out. I'm afraid to run any engine-on tests so I'm pulling alternator tonight for testing. I already ordered a new Mitsu piece because I'm sure that's my problem.
Did I fry my ABS controller?
