Alu box dust
mep1811
Gentleman Adventurer
I've noticed this aluminum dust in all my Alu Box's.
There is no dirt dust just powdered aluminum .
Anyone else notice this and know why this is happening?
Thanks
762X39
It is aluminium and it happens. Line your box with some closed cell foam (or whatever else you want to use) and it won't be an issue. I love Zarges aluminium boxes but if they are not lined with something, dust happens.
mep1811
Wow I didn't know that cardboard and ziplock bags would cause that much wear rubbing on the inside.
rayra
Try waxing. But also seconding the toolbox drawer liner material, either sheet or rubber-coated mesh. Either will really cut down noise and keep stuff form sliding around.
Rallyroo
That's one reason why I stopped using aluminum clipboards; all my papers inside the compartment got black aluminum dust. I got tired of my hands turning black after handling the paper. Plus the aluminum clipboard get hot from the heat. Using a plastic compartment clipboard now, not as durable, but it holds my gas receipts and paper maps, etc when on trips.
BritKLR
Kapitis Indagatoris
Mike-
Any further information or thoughts on this? I'd like to add a couple of boxes to the back of our Tiger. Thanks.
mep1811
Just got home so I'm in the cleaning and unpacking phase. I should get into the project phase in a couple of weeks.
mep1811
I would think whatever that is in the box would rub through it. I will go to harbor freight and get some tool box liner and line the boxes.
vtsoundman
OverAnalyzer
Vibration /movement on surface of aluminum...just about anything will polish or sand the surface.
Paint / clear coat then cover with material of choice. Less prone to etching and staining...and no corrosion. Bare aluminum is great if it is never touched.
luthj
Engineer In Residence
A fix is to find a local anodizing shop. The anodized finish is much harder, and won't be abraded by anything softer than sandpaper.
ilciclista
