Aluminum Channels for FRP seams and corners?
I was wondering where the best place was, to buy the Aluminum "channels" for the seams of a DIY camper? Hoping to find a source that sells the corner pieces, for example the edge piece for the the bottom overcab connection that has "legs" in the 3 planes.
java
Custom made is probably the easiest bet. Any local fab shop should be able to whip them up.
Sent from my SM-G973U using Tapatalk
Thats actually a good point. Especially considering i have access to solidworks and can probably design them myself haha
Peter_n_Margaret
I did not use any "corner pieces", just cut the aluminium bits to fit together.
The horizontals top and bottom of the bed-over were folded up because they are not 90 degrees.
And the 45 degree bits on the front L & R of the bed over are 3mm steel instead of aluminium to withstand the scrub impact.
Next build I will be using FRP pulltrusions instead of aluminium.
Cheers,
Peter
OKA196 motorhome
DanoWall
