(and yet another) Mini Harbor Freight Trailer build
Ted_Z
The trailer started life as the cheapest HF trailer kit then added a new 2000 lb axle, 225/75R15 tires/wheels and and a new tongue/backbone. The original kit tongue was cut in half length-ways and used to make the diagonal braces.
The box was built from 3/8 plywood and reinforced with 1x2 and 1x4 lumber at the joints/corners. The deck is 3/4" OSB and 2x4 lumber. All the wood was painted with deck resurfacer paint (in hindsight it was a bad choice). It has a working tailgate and the front panel is removable to carry longer loads if needed. I still need to sort out the fenders, but I'm running without them for now. The bottom of the box is 48" by 40", the top is 48" by 48". I hadn't built the matching lid so the first season I just used a tarp.
Last summer I did a 500 mile trip and it did great at highway speeds. On some of the rougher roads the sort slip springs seems too stiff (even with the 870 pound rated kit). Long term I may look at a longer leaf springs.
Basic Platform:
Ready for the first trip:
Inside and outside now painted:
Ted_Z
This spring I got the lid built and I am starting to fishing up the rest of the planned upgrades.
Primed lid:
Painted lid test fit with rack installed:
Test fitting spare for fold down mount:
Still to come front basket, fenders and Max Coupler.
rnArmy
It is amazing what all you can do with one of these little HF 4' trailers, and how much "stuff" you can haul with them. Love the military tub look.
Ted_Z
The top-most bolt acts as a removable pin, the bottom right is a travel stop. Pivots on the middle bolt that has a sleeve so it can be tightened down fully and not pinch the moving part. The tire carrier started off as a wrangler carrier, just added some box tubing.
Ted_Z
Minor update: I added a receiver to the tongue, and beefed up the joint with some fish plates. Welded a nut on so I can keep it from rattling by tightening a bolt and jam nut. Also by using a locking hitch pin it adds a bit security, as I can simply pull the coupler at camp. Now I can swap to a multi axis coupler easily.
wagex
i really like yours! welcome to the club of cheap Hf trailer builds! thanks for the idea for the cargo basket on front, mine will be getting one this weekend
rnArmy
I like the tongue jack on the front. Makes it a lot easier to work on when you can keep it level.
YaRiteZ71
