And yet enother issue with the sport... Tire cupping... ugh!
redraif
The uphill battle begins
2001 3.0l 4wd auto 245,000 miles.
some back ground. Ok so I have the 2in body lift and just got the new tires. At the time the tires were installed, the shop said they suspect the shocks were going up front. He said the truck felt very leany side to side to him... body roll wise. I did the bounce test and it seemed ok. Even popped it over some speed bumps on video and it did not have excessive bounce. We assumed they were ok for now. I wanted to do a susp lift when it was truly time to do a shock swap, but at that time, we had just sunk way too much cash in the beast right then just getting it road worthy. Plus mom needed to borrow the truck. Mom could not drive it if I had done the Susp lift.
Mom had the truck for a while and we just got it back recently. She won't need it anymore as her car is fixed! YEAH!!!! So it was going to be the weekend toy. Again no hurries on anything. We were saving up to deal with the dang bad cat. But then we had to put it into daily duty when the civic blew one of its new used tires... Civic really needs 4 new tires. Had bought used tires to get buy. The Sport had been sucking so much cash to get road worth for Mom. So we had put the civic on hold longer then we should have. And then it bit us in the butt with a sidewall blow out. Of course it came when we were putting together our wedding (August 15th) and we had no extra $ again. Anyway, the sport has been pulling full duty since mid August. Again not a biggie, thought ok just till we bounce back from the wedding in a few weeks and could get tires on the civic.
But nothing works like that in my world. To add to the CELs and odd clattering... Now I noticed something new on the sport... I drove it into the garage after a rain (the tires were cleaned off due to the wet driveway) but the garage had dust on the floor. The Sport then picked up trace of dust on the tires and I saw it. There is cupping starting on the outer edge of the front tires. Really... like I need this on top of everything else...
So I know it can range as far as causes. But something suspension for sure. Could it indeed be the shocks? Or could it be something other then the shocks? Could it be just out of alignment? Or have the "alignment parts" failed, thus and alignment would be a waste without fixing bad parts first (tie rods, ball joints, bearings, control arm bushings, idler arm, sway bar bushings?)
It has not been aligned while we have had it, but I did not notice and crazy wear on the old tires, but they were a hot mess from the get go.. Daughter got them used. Do I maybe go somewhere that offers an alignment where they will "re-adjust" for free within a certain number of miles or time? Let them see if they can get it factory spot on (with a print out) with the existing suspension components? Usually they notice at that time if something is amiss right... aka won't align. Then rotate tires... front to back... Then go back in a month or so for a free check up to see if the alignment has held. If it holds then say ok... components are ok? Keep checking the alignment often?
Then there is the side of me that knows this beast has been neglected... it has 245,000 miles... Based on the looks of the bushings on the tie rods... everything has not been touched in a while. tierod boots could use replacing just cause they look bad. I could eyeball the joints then. See if they move smoothly. But at that point, things are apart... the effort has been made... is it really that much more to just replace them? With no background and known spotty care. Is it just safer to replace, to be sure. Yes that's $ I don't want to spend, but.... I plan to keep the rig and get it set up to be bullet proof and a safe occasional off road rig. Should I just "buy the insurance" of new parts to KNOW everything is 100%?
Do I have to use Mitsu parts or is something through rockauto or summit racing ok? Who is the best brand to use if I go the replace route?
Honestly I'm not good at diagnosing suspension stuff unless its obviously broken. I hate to just open my wallet and start replacing without a plan. But if it means just paying a shop an hourly rate to check and replace, I might be better ahead $ to throw parts at it... LOL! I mean it does have 245,000 miles. Low miles that would stupid, but with this many miles and no idea what the previous owner did! I feel sure I can replace the components (except bearings), I just don't have any idea how to tell what is bad. Yes I'm a girl, but I completed my own coil over conversion on the rear end of my fiero alone. Swapped all its bushings to urethane. Removed, painted and reinstalled all its suspension components. I lowered the Mustang and installed its camber plates.
Give me good instructions and I can do it. :) Just was never taught to diagnose suspension failure. Just bought aftermarket and replaced for a tighter performance suspension.
Where do I start. And yes the Sport will be pulled out of full duty ASAP. The civic will be back on with new tires ASAP so I can figure this out. I'm not trying to eat up my good tires!
As I said earlier...I had planned to do a suspension lift in the near future, just not right now. But if there is a chance I have to replace the shocks, then I want buy the right stuff to plan for the lift. I don't want to buy shocks 2x. I have been told that the fronts don't need to be any special length even after you lift it with the torsion bar adjustment. So I will be ok to just do the fronts for now, but I want to buy right so I can match up to the rears. Not trying to run 2 different brands or styles. If I have to buy new ones I would rather buy correctly for the near future lift. I already have the spouse on board for the lift to come soon as we have been getting annoyed with mushy rear coils and want a stronger coil. So that means the lift is approved when the funds are available. :) I want to go 2in with either OME or Iron man. What ever is better for my rear coiled sport. I was planning Heavy duty in the rear and I hate the mushy OEM versions. Will stick with stock front Torsions for now and upgrade to heavy duty if I go to a bull bar in the future. I do plan on a winch though now matter what. Was going to set up a front mount hitch receiver and the winch on a removable hitch style platform. Easier to keep it clean and safe unless I'm off road or planning to drive in snow/ice.
sorry for the length post. better to lay it all out from the get go! :)
BEG
Dude, she's a girl :)
Other than that, I have to agree. 245k is a lot of wear and tear. With that much mileage and spotty maintenance, for every one thing you fix, three others break. I'd consider cutting your losses or, if you really love the truck, take it off the road and bring it back to stage zero (as close to factory fresh as possible) before considering any modifications.
jeep-N-montero
The word 'dude' can be used in male or female context and does not denote sex, carry on.
HARDTRAILZ
Certified
I don't even own a mitsi and from seeing the near daily new posts whining about this rig and another issue, I will never own one.
jeep-N-montero
Many of us simply change the oil and drive on, the OP picked up an ignored and troubled child and has been trying to nurse it back to health ever since. But kudos to you.
HARDTRAILZ
Certified
Good to know they are not all like this. I guess if it had been confined to a problem thread or build thread it would not have made the platform look so bad since hitting New Posts brings up more than just this one issue thread.
redraif
This was more where I was leaning... back to square one. At least the money invested will last another 200,000 if I actually take care of it unlike the PO! I just wish I had know when we were in doing other stuff like valve covers and spark plugs... just do the dang valve seals since its already open that far... lol! Replacing the timing belt... whats a few pulleys while you are already there versus going back after it after the fact. Yeah hind sight.
This is why I'm wondering if I simply say ok... take the front end apart and replace what I can... At least I know its true and will last and I won't have to go back in after it later. A lot can be said for proper diagnosing, but sometimes when there is enough overall wear the $ is better spent to make it new.
Well to give you a back story.... this beast was dead (tranny) and my daughter wanted it and paid a good portion to get it back going. She decided she did not want it after she got over the big car phase in her life. There were no bites on buying it and honestly we were in too deep $ wise to take the $ we would get for it. And honestly with the miles on it... this crap is to be expected. I just did not expect it all at once! :) Little here little there to bring him back to near factory... no prob. I don't mind. Just need a little break between! LOL! Its a stout rig though. Been impressed with what it has been through and still is going. Would I take on one of these rigs all over again... not @ 225,000 miles... maybe on a 60,000 mile rig... Then I know I will do what needed when its needed and won't have a nightmare down the road.
All the folks here have good longevity stories and speak highly of this rig. This is why I'm willing to try to give this fellow a new lease on life. Just hard correcting so much PO abuse
HARDTRAILZ
Certified
I can appreciate saving a rig, but 3 threads in three days makes it seem like dead rig. Sometimes you lose money and are better cutting ties.
bikerjosh
I'd like to think that part of his reason for posting is just to make other Montero owners feel better about their less significant issues, like a burned out AC fan. :sombrero:
BOPOH
i'm pretty sure everybody can attest to at least one love/hate relationship with their vehicles, and at one point it just turns into a hobby or like a therapeutic thing. I've always had a spare car or truck to wrench on, it's makes me happy(even if i curse and destroy things) :)
redraif
LOL! Exactly... my older cars are the only reason I know how to do anything on vehicles. Learning to do things and fix them yourself is a dying art. I want to learn and understand. I lost my best buddy over some stupid stuff and don't have anyone to wrench with and learn from anymore... so I look to the forums.
Folks... Any chance we can get back on track and tell me what to focus on! :) You know I'm not throwing in the towel just yet! :)
HARDTRAILZ
Certified
Get an alignment. It will be fixed or they will tell you if you need parts.
Have you rotated tires lately?
Have the tires been properly inflated?
travelall74
