WagoneerSX4
Sorry for another question that probably seems really straight forward, but nobody can give me a straight answer. Are there any difference in the firestik antennas that come in the NGP kits compared to just a regular firestick fiberglass antenna? I'd like to swap out my 3' antenna for a 2' antenna (getting sick of smacking the thing every time I go into my garage or smacking pipes in my underground parking at work) and I'm trying to figure out if I can just replace it with a regular 2' antenna.
Here are the reasons for my confusion. The antenna that came in my NGP kit doesn't have a part number, just the entire kit has a part number. And on the kit itself it says very plainly that I cannot modify the length of the coax cable or use a different antenna with the cable. This makes sense, but the antenna part doesn't. I compared my 3' antenna with a friend's 7' firestick antenna and everything looks identical, right down to the tunable tip (and obviously the actual antenna wire isn't wound as tightly as my 3').
So is there anything stopping me from just swapping my 3' out with a 2' and retuning the SWR's and calling it a day? I've emailed firestik with no response, I haven't tried to call yet though.
I'm sure the difference in the NGP kit is only the coax cable and not the antenna's, I just want to make sure.
TIA
TIA
