any users or comments on EVANS waterless coolant in Toyota Diesel??
roberto
Wanted to get consensus of EVANS waterless coolant, was thinking of putting into my Toyota BJ42??? Pros, Cons?
Thanks
Rob
SunTzuNephew
I run Evans in my gasser Yukon (350cid), MBZ300D, my Excursion with a 7.3 PSD, and my diesel generators....I'm a beliver, I'd use it in my pickup (6.4PSD) if it wasn't under warranty and wouldn't be replaced.
The science and engineering behind it is solid, as far as I'm concerned. I haven't had any problems with using it.
Byrdseye
I've used it in 7.3 PSD's , 5.9 and 6.7 Cummins as well as Ducati race bikes. It's good stuff and works as advertised. Also, you don't have to worry about cavitation additives if they are needed for that engine.
For what it's worth, a new non-toxic coolant based on recycled glycerin from the biodiesel manufacturing process has just been introduced (Fleetguard I think) I don't know how it compares to the Evans in regards to it's physical properties. (gotta look that up) but it's interesting to note that there is a non-toxic alternative to propylene glycol based coolants.
ntsqd
Heretic Car Camper
Water Paper on the use of a sugar beet by-product used for coolant.
  • Betaine-Water Coolant.pdf
xander69
