Anyone build their own custom truck tool boxes ?
Skim
Just wanted to see if anyone has attempted to build custom tool boxes for trucks before ?
Any pics ?
soonenough
IIRC TejasYota from TTORA (who's also here on ExPo I think) had one custom built by a guy out of San Marcos, TX. I remember reading a thread about it on TTORA. The guys name that built the box escapes me but I'm pretty sure it was all custom fab'd out of steel not AL.
EDIT: found the thread http://www.tacomaterritory.com/forum/showthread.php?t=26062 For some reason I remember there being more pics though...
Cody1771
its actually pretty simple to do... i have built a few. depends on what materials you want to go for. if you want something strong and cheap 2x4's and plywood works as long as you seal the wood well. but they can get very heavy very quick. aluminum is my prefered method. make the frame you want out of 1" x1" angle then weld on some aluminum diamondplate or even just sheet metal. can make it look just as good as a store baught one that is customized to what you want... i made one that was custom fit to house a honda "whisper quiet" generator that had air intakes and exhaust plumbed through it, along with circuit breakers and a battery charging system for a buddies dodge 3500 that he tows a motor home with. i have yet to do one for my truck just because i want to decide on what i want to do with it first. steel is cheap but ultra heavy. good if you dont ever plan on removing it :p Canadian tire or walmart has some good ones in the $250 - $300 range... Delta is the brand name i believe.
Edit: steel is cheap if you can make it out of scraps, otherwise its only cheap compaired to the price of aluminum stock.
Skim
I have been thinking of building a frame out of angle first also- glad that works.
The skin will be steel for ease of welding.
Any pics ?
inked33
personally imho a frame even if it is just angle iron just adds unnecessary weight to the box that isnt needed
JPT4648
