Anyone Know Bigfoot Camper's Wall Construction?
deminimis
Has anyone looked at the interior wall construction of a Bigfoot truck camper? I'm needing to install/build a drop down upper bunk bed in our 2500 series camper and I'm wondering if there are studs in the wall to tie into. Hate to pull the skin to see, but guessing that's my only option (unless someone has already been down this road). Specifically, I'm looking at the area around the dinette. Here's the plan:
deminimis
Thank you for the reply. They had a 3000 series which used Alumn studs. I should have mentioned mines a 2500 series (clam shell design) which didn't use alumn studs. Can't remember if there are any studs. Seems like I once read there were some spruce studs in there, but not sure. Heck, if so, they ought to call them "stringers" as opposed to "studs" as its closer to boat construction than camper construction.
cnynrat
I'm pretty sure there are some wooden frame members buried in the walls of a C2500, but I'm not sure where they all are. When we bought ours (1999) there was an option to put a fold down bunk over the dinette, so I'd guess there is enough structure in the wall and/or ceiling to support such an application. Some structure would be needed inside the walls to support all the cabinetry as well.
I'd suggest you contact Bigfoot directly, or you might try the Bigfoot Owners Club. I've been able to get some good information from people in the club.
deminimis
Thanks cnynrat. I tried out that board when we got our Bigfoot. Really didn't find it very helpful (unlike here), so I didn't opt for the $30/yr subscription when it came time.
I've emailed Bigfoot and I'm hoping for a reply. That's very good to know that BF offered a drop down bunk option at one time. At least it gives me hope that there's something to tie into and it will hold.
Thanks again!
DDW
I have a 2500 as well. There are some wood sticks in the laminate, but they are just glued in there with what amounts to contact cement. You would be able to find them with a capacitative stud finder. Everywhere else there is just extruded polystyrene foam. Their construction method was to mold the top (and bottom), spray it with adhesive, apply the foam and sticks where they wanted them, more adhesive, then the interior paneling. No vacuum bagging or anything like that involved, just lay it in there and pound it down with a rubber mallet.
deminimis
Thanks DDW. Yup, heard from BF this AM. No studs in the wall. Well, I've got a "Plan 'B"" to fall back on. Thanks again folks!
Ace Brown
Retired Ol’ Fart
Good to hear that Bigfoot has come back. I always admired their designs.
I once owned a sailboat with double hull construction close to how a Bigfoot is built. I wanted to install a motor mount on the stern but wondered how these two unsupported layers of glass would suport it without simply compressing/breaking. The boat builder offered this tip. Buy a squeeze botttle of mustard and clean it out. Fill with epoxy. Drill holes where you will mount the bunk from the inside. With some kind of probe (dental or just a coathanger) work out a big open pocket in the foam under each hole. Use the bottle to squeeze this hole full of epoxy. Tape over the hole and allow plenty of time for epoxy to fully harden. Locate and drill holes for each bracket but only big enough to accept a lag screw into the epoxy as long as the wall thickness will allow w/o popping through. If two or more bolts will be mounted close together I would clean out all the area behind them so the epoxy block is one solid piece. When the factory mounted accessories on the camper usually a solid block of wood is epoxied between the shells during assembly. Squeezing in the epoxy as I have described is essentially doing the same thing except the block of epoxy becomes the hardwood block.
This worked very well on my boat. I had a 4 HP motor on a 21' sailboat and despite running aground several times, even in reverse where the mount took all the stress, no damage was ever done. However I would limit the bunk to kids and other lighter sleepers just to be safe.
Alan
deminimis
Thanks Alan. Once I started measuring everything up, it became apparent that a drop down wont work in the space. I have a simpler design in my hea
Code:
d that I'm going to build once I order up some 1.5" alumn tubing. I'll post the build when I do it.
Code:
BCHauler
Based on their pricing in the used market around here - I'd guess solid gold.
dare2go
If you have a roof air conditioner you only have to take off the filter to see the cut through the roof = that should give you an idea about wall structure (pretty flimsy and cheap polystyrene).
:wings: True - plus ours didn't survive the trip to South America very well...
MegaRoamer
Code:
Code:
Just curious if you completed your project using the aluminum pipe and so see if you have any photos of the work.
dave
deminimis
Not yet. Been busy siding the house (and riding motorcycles, boating, etc.). The BF bed is on the back burner and not much of a concern now. I are generally towing a race trailer, so will purchase gaucho beds for the race trailer and let the nuggets sleep out there.
