Anyone looking for an adventure? Free Dodge Ram + Truck camper in Belize...
Christian P.
Staff member
This was just posted on the PanAm Travelers Facebook group...fly in with your points, get the truck to Mexico, get it fixed and drive it back! Being a manual transmission on a 2WD, I can't imagine it would be too hard...
FOR SALE @COROZAL BELIZE
-> PRICE: €1 (THE BEST OFFER)
-> IMPORT FEE OF $750 to import in Belize
-> Transfer of ownership can be done from abroad
-> Not ready to drive (read below)
Contact if interested for more info/pics via pm or WhatsApp 0032 4 85 84 29 93.
DESCRIPTION
Hi everyone! We are two travellers from Belgium and are selling our beloved “Chula”, a cosy home built on the wheels of a solid 1996 Dodge Ram 2500.
When we arrived in Belize we unfortunately experienced car problems and the transmission broke. We tried to fix her but because of a time schedule we could not stay in Belize. As a result the campervan still needs to be fixed.
-> A mechanic installed a new transmission but this was badly done and caused the bell housing to break.
-> These things need to be repaired. There are two good options:
1) We would suggest to tow the car to Mexico in Quintana Roo because it is part of the free zone, no vehicle permit required so the car can stay here as long as needed plus it’s easier to find the proper parts in Mexico than in Belize.
2) You could also order the parts online from the US and let the car be fixed in Belize.
INFO
The compact dimensions and patched up looking outside allows you to go and park anywhere under the radar. Whilst the spacious inside is well equipped with a fixed bed, full bathroom and even an oven, so you can comfortably enjoy freshly baked nachos in your sofa. There is plenty of storage room, as well as enough solar power to charge all your electronic devices.
SPECS BELOW
PICK UP
-Dodge Ram 2500, 1996
-American plates (making it easy to change ownership abroad and definitely in the USA). [Happy to help you upfront for all your paperwork of the transfer procedure so you're good to go once you get the vehicle.]
-V8 / 5.9L / gasoline
-115 000 miles
-Manual transmission
-2 wheel drive (2X4)
-Stereo with USB and Bluetooth connection
-Regular cab with storage space
Although the car is from '96, it has a very strong engine that does its job fully and never let us down. It has taken us everywhere we wanted to go and no steep hill was too difficult. The speed/kilometer reading doesn’t work anymore, but we decided not to fix it, because we always use Google Maps for navigating, which also shows the speed.
Over the years, the car had good mechanic maintenance, no problem left untreated:
• 2022:
-New power steering line
-New brake cylinder
-New tire
-Renewal of motor & steering wheel oil and change of brake fluid
-New water pump
• 2021:
-New brake pads
-Changed oil and filter
-New plugs
-New spark plugs, wire cable, distributer cup and rotor
-Fuel injectors adjustment and new MAP sensor.
-New car battery
• 2020:
-5 new all terrain tires
• 2019:
-Replacement of brake fluid, oil filter and air motor filter
CAMPER
Very spacious slide-in SportKing camper, fully renovated in 2020. Small crack above the door, but the door closes well.
Some small repairs to the outside which we have travelled with without problems. There is one rooftop window missing (I can send you the link on Amazon it’s around €50). And at the front near the sleeping cabine some of the plating was torn off. So the insulation is visible but it did not give us any moisture problems.
• Water system:
-110L tank , electrical pump (12V) (for sink, shower & toilet).
• Electrical System :
-Solar panels 3x100W
-4 batteries (new since '21)
-2 new solar controllers
-Lighting 12V LED
-Fans (12V)
-Converter 110V
-Fridge 110V 90W
• Features
- 1 double bed (new mattress 2021) with cushions and sheets
- A lot of storage including full-height wardrobe
- Bathroom with toilet and shower
- Kitchen: fully equipped for cooking and baking. Gas stove (4hobs) and oven (gas bottle 22lb - 10kg)
- Wide tool kit for fixing and maintenance of ther car and camper (just in case..)
- Outdoor equipment: 2 camping chairs, 2 folding chairs, folding table, cosy light garland, hammocks
- Snorkels
Fully equipped.
PM or message on WhatsApp for more information
shortbus4x4
Unpossible that rig could do the Pan American. You need 4x4 or better yet 6x6 and a biiiiiiiig camper with solar and a battery bank that could power a small city.
That would be an easy fix. Fly down with a new bellhousing and install it yourself with a floor jack and some hand tools.
