General Automag
We're considering installing a propane tank in our recently modified M416 trailer that we've modified for camping. There's not much room inside the 1/4-ton trailers, as you know, so we're looking for the best way to install a propane tank. We've seen smaller propane tanks installed on trailer "corners" and some on the tongue. There are some very neat propane tanks out there too such as the see-through tanks from Lite Cylinder http://litecylinder.com/, but they are expensive and cost as much to refill as does a 20lb. tank. Plus, it's sometimes difficult to find a business that refills propane tanks.
We all know that the 20lb. tanks are available almost everywhere. If you do have one of the smaller tanks, you have to find a business that will refill them, and then they usually charge the same price to fill them as you would pay for a 20lb. filled tank. (Now we all know that some stores are filling the 20lb. tanks to 15 and 14lbs. because of the rising price of all fossil fuels and our declining dollar (thanks Obama) in order to keep the retail price for a refill the same price for the consumer, but for the sake of this conversation, let's assume that we are buying a full 20lb. refill).
Is anyone using the 20lb. tanks? Where are you installing them? Here are some pictures of our setup. What would you recommend? If not, please post pictures of your "other than 20lb. tank" setup if you've had good experience with yours. Thanks
