anyone use a wagan portable solar unit
Wildcat
wagan tech
anyone have experience with one of these? local on cl has one for bout 2/3 the price of new. still a bit pricey though. is it anything that i cant build with a wheeled cart and panels/controller/inverter?
unseenone
Based on the specs, if you used the inverter at capacity, 1500watts, you'd be flat in about 15 minutes. Recharge would then take 16-24 sun hours, which amounts to 3-4 days maybe depending on conditions at 10amps max, although it will never achieve it with an 80w solar panel, the best you could hope for would be 4-5. The most I see on some 90-100 watt panels at times is 5.
I agree, build it yourself, or keep shopping.
iStan814
