ARB 170201 fitting.
HAFICON
Anyone have a recommendation on an alternative for ARB fitting in he solenoids? Seems every so often I have one let lose hey average about $18 each with shipping. I looked into a standard compression fitting might try that route. Any alternative fixes please shout.
Part:
https://www.northridge4x4.com/part/...3QJLv1IBJ4fRImvYWllvoty0JlLi1slxoCl20QAvD_BwE
Optional: but would have to drill an tap the solenoid that is doable, and this should be fail safe.
https://www.amazon.com/Compression-Fitting-Stainless-Steel-Connector/dp/B07FZ88NM6
Thanks,
James
So I have bought a lot from this company but I do not see anything there. But just waned to share:
https://www.pneumadyne.com/
IdaSHO
IDACAMPER
So what threads does the fitting have?
Can you not just swap out the fitting at each end of the line for a more-standard (5mm... really??) air line fitting, like 4mm or 6mm?
Leave it to ARB to make a proprietary fitting :ROFLMAO:
IdaSHO
IDACAMPER
Also, it does look like 5mm is available, just not as standard as 4 or 6mm, so the fitting availability is limited.
Grainger has a few options, like this one...
Again, need to know the thread size/type needed as well
https://www.grainger.com/product/AIGNEP-USA-5mm-Metal-Male-Adapter-1WUL2
Mcmaster-carr has some available as well
https://www.mcmaster.com/push-to-connect-tube-fittings
like this one...
HAFICON
Gonna look into that when I get home, the thread size is small but I don’t know right off. I may call ARB tomorrow ask them, for an easy solution I went ahead and ordered the ARB fitting also ordered the one I referenced see what I can make happen. No local places carry any compression fittings this small.
TheGetLostTaco
We go places
I purchased mine from an online store in the UK since ARB uses BSPT standards. Worked great. I did not pay rush shipping and received them in 5 business days and that is going to through US customs too.
javajoe79
Fabricator
If they are 1/8 bspt I would be inclined to replace them with a 1/8bspt to AN3 fitting and use AN lines to connect them. You’ll probably never have to deal with it again.
Houie
