I have read several threads but wanted to double check my thoughts and get the best and easiest connection for my arb fridge. In the past I ran my fridge 24/7 of my starter battery which was an Odyssey 48-720 in my Jeep. It was wired with arb wiring kit from fridge to battery. I drive multiple times per day for work which helped recharge the battery. I never had any issues with a dead battery and I could go 3 days without starting in Texas heat on that setup which was ran for 1 year.
I have a new truck and I want to wire my fridge back up. I'm considering a slightly different approach and want the best way to set it up. My driving habits are the same as above. The Truck rarely sits longer than 12 hours without being driven. My fridge is always stocked for my kids who have more tball and baseball games than mlb players. The truck is a raptor with an oem agm battery from Ford motor performance ( not sure the maker but it's a bagm-94rh7-800). I still have my Odyssey 48-720 and want to wire this battery for the fridge. The fridge will be mounted in the back in an arb extended slide and the Odyssey will be mounted behind it in the slide.
the Odyssey will only power the fridge and my plan is to have the alternator recharge the battery. I am looking at the blue sea add a battery kit but I have seen alot of threads and use with the blue sea ml-acr being used.
What would be the best product to use to have my starter battery as a starter, my aux battery for my fridge, alternator to charge both. I also hope that the system will be automatic and i do not have to turn on or off the system manually. Thanks for any help in helping me finalize my system. My kids are dying for me to hook the arb back up.
