ARB 50qt Fridge in a JKU?
Bennyhana
The new ARB 50qt fridges fit like they were specifically designed for the JKU's. It fits perfectly in the back and even lets me open the lid.....even with the top on.
I've fabbed up a flat platform so I can secure the fridge down and have since upgraded to the ARB fridge tie down straps.
JIMBO
:sombrero: Heh Heh, yeah and when you get your trailer-getta sPOD, I've gotta 12vdc outlet and 300w inverter at the drivers side hardtop rear and the outlet will easily handle the demands from my Engle--never carried it there--just trieditout !
:costumed-smiley-007:wings: JIMBO
Power Wagon Family
I Hate Off Camber
Such great info on here! have an idea of the way i am going to set it up and will make sure i post pictures when i am done. Thanks again for all the info.
dp7197
My original post is under te Storage Solutions Thread:
http://www.expeditionportal.com/forum/threads/9034-Post-up-your-drawer-storage-system/page78
The aluminum is about 38" wide, 10" tall, and 28" (?) deep on the bottom piece. It has a 1.5" lip to rest on. It was designed to hold four Pelican cases or varrying sizes in place. The rear of it is held down by two tie-downs I mounted in the underside and then running a 1" ratchet strap through all four tie downs. The front uses tow 3/8" bolts through the plastic trim to nutserts in the floor. I wanted to bottom to remain open so I could still use the storage compartment.
The next sheet is only 4" tall to accomodate a plastic folding table and the depth is 2" shorter to accomodate the slant of the rear seat. There is no back to this and the table slides all the way through to hit the rear seat. I did not keep the sides even o this, but gave it a slight bow to help deal with the weight on top. Even though it bends down some due to the weight, the poly table slides out easily.
My ARB fridge slide is on the top and while it fills the void, it is too tall to see in or open the lid. I figured I would probably remove it anyhow. The other option is for me to remove the middle piece to lower it 4". I alos am thinking of just placing it on the passenger-side rear seat on a leveling board with no slide. We did this in a friend's Jeep for 5k miles out to Moab and it worked nice. If I do this I may sell the slide and install Mac's tie-downs on top the aluminum for the table.
The smaller rear box just fills the void and keeps things from sliding around. I installed one vertical and one horizontal strap using footman loops last weekend to keep things off the glass.
The best part are the two small trays on each side that hold two zippered bags with straps. One side has fluids and the other all my CO2 and air stuff. They are out of the way but accessible.
These were all assembled with round head bolts and acorn nuts.
Yulli
Yulli the Yeti
When you guys say change out the 12v plug, are you taking the one off from the ARB wire kit and replacing it with the Marinco plug?
nigelish
Nigelish
I have tried the center console for my Waeco and it does not put enough power into it, after about 10 minutes it shows 'fault', so going to run a direct line from my battery until I set up my solar generator on my back rack.
Nigel
