evomaki
I am considering the purchase of a rear ARB Air Locker and installation of a 4.90 gear set in a 2000 Montero, which does not have a factory locker. I think there must be some sort of difference in the third member gear carrier width between an air locker equipped vehicle and w/o. I can only assume the gear carrier must be wider on an air locker equipped Montero? But I really don't know. When swapping a third member (say from an SR) to a non-locker equipped vehicle, posts on this message board have talked about the need to replace the driver side axle with a shorter axle from an air locker equipped vehicle. The ARB catalogue indicates my vehicle would require locker part no. RD 154. I am trying to prove positive that this will work, given what I think is some difference in the gear carriers on these vehicles. I have emailed ARB with the same question. No reply as of yet. I just don't want to spend a ton of money, get this all torn apart, and then find out there is a problem. Thanks for the help.
