ARB Antenna Bracket? Size?
S
Street Wolf
Guest
I'm thinking about purchasing a few of these things, but every picture I find of them is up close like this with nothing to give you a size perspective. Does anyone use on of these, and can get me a picture of it installed on your ARB bar or something?
Thanks.
CanuckMariner/Nomad
Love having fun 😊 in the 🌞 by the ⛵ and the ⏳
These are about the size of the palm of your hand. The two loops fit over a standard ARB bull bar (2" IIRC). The hole may have to be drilled a bit to fit your antenna mounting stub.
The unfortunate thing is the powder coating comes off and then rust sets in quite quickly. I have a pair of them mounted for about a year and they have already begun to rust. :costumed-smiley-007
S
Street Wolf
Guest
I've got one to sell you and I'll get you a few pictures.
A
Thanks. I already purchased a few of them between now and the time I posted. Sorry I didn't see your reply before then.
I just welded a little plate on mine for the antenna.
Thanks, the hole should be the correct size for what I'm needing to do. I just didn't want these mounts to be ridiculously large and stick out like a sore thumb. However I wanted them do avoid actually having to remove the powdercoating on my bull bar to weld tabs or something of the like.
Rallyroo
My ARB winch bumper had two antenna tabs build in (nothing extra to buy and nothing to weld). I use one tab for my 2m/70cm dual band ham antenna and the second tab for my CB antenna.
cruiseroutfit
The 80 Series bar does in fact come with 4 tabs and the bracket shown by the OP is available both in a light stud size and antenna style. I've got both here if you can't find any relative shots.
iStan814
