The kit includes 10 gauge wiring to run from the engine compartment to the rear of the vehicle. One end of the wiing harness has 2 per installed eye lets to attach to battery. About 6" from the positve lead end there is an in line 10 amp all weather fuse. At the fridge end there is a nice hella plug that installs quick any easy to a plastic panel. The kit includes wiring quick connects to make the install easy and painless.
Things to note:
ARB indicated the battery end eyelets were 3/8" so they will work with the military type battery lugs. Unfortunately they were actually 1/4" so if you have a larger bolt on the lug you will need to cutoff the ARB installed ones.
The quick connect clips are kinda 1x use. They do not unclip and reclip very well.
The hella style outlet on the end was dead on arrival. I am trying to reach the vendor right now for a refund or replacement.
Overall it is a clean easy way to wire the fridge. But if I was to do it again I would make my own harness and save the $50.
Things to note:
